| Message |
I decided to try my luck by inserting the connectors without de-pinning them. After a few failed attempts, I found that by inserting the smaller connector (on the shorter end of the wiring) first, then once that makes it through, inserting the larger blue connector, I could have the harness through in a minute. Others have also done this successfully and documented it on the Forum, too bad I had to learn the hard way.
_________________________________________________________________________________ "The Z is the cause and the solution to all my problems" -- Me manstretch: well, my rear end is just worn out ZEngineer24: sig quote
